2002 Mazda b2200 Oil residue on the spark plugs
2002 MAZDA B2200
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
RANDALLEAKES
My truck started vibrating, losing power going up hills and the check engine llight came on yesterday. So I went and had a Dianostic test ran to see what the error might be. The test came back with an error for TCS (throtle control sensor) so I changed it out and the old one was definately no good. The truck in park still had heavy vibations so I thought it maybe a ignition problem so I changed out the spark plugs and wires. When removing the old plugs I noticed that the plug had oil residue (not carbon) even a small drop of oil was on one of the plugs. After changing them out the truck still idels rough and has a huge decrese in power. could this be head gaskets and rings???? Mazda B2300 Thanx
Jun 19, 2008 at 1:51 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would first do a comp test and a leak down test, this will give you an indication as to the condition of the bottom end. do this and report back your findings.
Mark (mhpautos)
Jun 19, 2008 at 5:16 PM
