1993 Mazda b2200 Sudden loss of power while driving
1993 MAZDA B2200
COUGAR1969
Engine Performance problem
1993 Mazda b2200 4 cyl Two Wheel Drive Manual 306K miles
While driving home from work, my truck was running fine and then I experienced a sudden loss of engine power and the check engine light came on. It will barley idle and then die if I give it more than 1/4 throttle. I was able to drive it back to my shop but only got 40MPH out of it if I babied the throttle. At this point I am unable to start the vehicle and it has been parked for several days. This truck is a fuel injected model and I understand that there weren't too many of them produced and It has a different computer than the carberated ones. ( I replaced the computer last year )
Feb 8, 2010 at 5:25 PM
DAVIDSIEVERT
I just bought a B2200 Mazda last week and it ran fine for a couple of days and the exact same problem has occurred. Has anyone come up with a diagnosis since Cougar1969 psoted his questio 2 years ago?
Sep 6, 2012 at 9:20 PM
ADRIANTBIBBY
i had the same problem when i got mine. i replaced the distributor cap and set the timing. i think timing for this model it 8 degrees. firing order is 4213. it helped a bit. i removed the catalytic converter. it plugs up so bad and restricts the exhaust and drains power just how you described.
i also had to replace the high temp spark plug wires.
hope it helps.
Dec 1, 2012 at 11:38 PM
