1992 Mazda b2200 tail lights
1992 MAZDA B2200
AANTIQUINA
Electrical problem
1992 Mazda b2200 4 cyl Two Wheel Drive Manual
I recently changed the factory radio to an aftermarket radio. After the installation was done i noticed that the dash lights and the tail lights were not working. the fuse was blown and when i replaced it it blowed again. i got a volt meter and checked continuity. there is 12v on the primary, but when i turn the swith on the secondary goes to ground. i removed all the lights and still no change. i unhooked the new radio and still no change. any ideas?
Jun 7, 2008 at 2:58 PM
What fuse is blowing is it the room fuse 15amp or the cigar fuse 15amp? I viewed the illumination circuit you could have shorted out the blue and red wire going to the radio-
Jun 7, 2008 at 5:17 PM
AANTIQUINA
the fuse that is blowing is the 10 amp that is located in the tail slot. top right slot of the fuse box.
Jun 9, 2008 at 9:52 PM
