This truck has a two piece drive shaft supported by a bearing hanger assembly in the middle. This drive shaft has two different size u-joints. The front and rear u-joint are the same size and are "Swagged" into the yoke, the center u-joint is a different size and uses c-clips. I can find a replacement joint for the center but the outer u-joints are an odd size with no replacement parts. I've been told that this shaft cannot be rebuilt and that I must purchase a $400.00 aftermarket shaft. Surely someone makes a u-joint that will work. Can you suggest a less expensive way to resolve this issue?
Aug 12, 2009 at 11:00 AM
