1990 Mazda b2200 Replace pads & turn rotars
1990 MAZDA B2200
13,500 MILES • 4 CYL • 2WD • AUTOMATIC
KFREDERICKJR
Need disassembly instructions
Aug 31, 2008 at 9:40 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/how_to/how_to_replace_brakes.htm
FRONT DISC BRAKE ROTOR (PICKUP 2WD) Removal & Installation (B2200 & B2600i 2WD) 1. With caliper assembly removed, remove wheel hub grease cap, cotter pin, lock plate and ring adjusting lock nut. Remove thrust washer and outer bearing from hub. Slide hub and rotor assembly from spindle. 2. Mark rotor-to-hub position. Separate rotor from hub. Machine rotor if lateral runout exceeds specification. Replace rotor if measured thickness is less than specified minimum thickness. See DISC BRAKE SPECIFICATIONS at end of article. 3. To install, reverse removal procedure and evenly tighten rotor-to-hub bolts. Adjust wheel bearings. © 2007 Mitchell Repair Information Co., LLC. Page 1 of 1 DISC & DRUM -1990 Mazda B2200 8/31/2008 http://www.ondemand5.com/mric/common/asp/printart.aspx
Aug 31, 2008 at 11:40 AM
