where do i set the timing
1989 MAZDA B2200
235,000 MILES • 4 CYL • 2WD • MANUAL
GMMAN00
  • 8 POSTS
The timing belt slipped on my truck and i was wondering where do i line the top pulley up at, i have the bottom one at 6deg BTDC. Do i line the top pulley up with the number 1 at the arrow or there is a little circle make just before the 1, im not sure if this is where im suposed to line it up at.
Nov 9, 2010 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2922.jpg
Nov 10, 2010 at 6:27 PM
RACER_916
what should the cam and crank position be for the timming on a 1986 mazada b2200 can u describe how the cam wheel and crank wheel should be?
Jul 18, 2019 at 12:29 PM (Merged)
Put the engine no.1 piston on its compression stroke/TDC and make sure the rotor is pointing to the no.1 cap tower
alignment
BROOMESH
what is the torque for the crankshaft timing gear (sprocket) bolt on a 1988 Mazda B2200?
109-152 in lbs
BROOMESH
I believe the torque that rasmataz has given me is for the six small bolts that attach the crankshaft pulley to the timing gear. The torque I need is for the large bolt that secures the timing gear/sprocket to the crankshaft. I suspect it will be alot of torque in the range 75 to 120 foot pounds. This torque is not listed in the Haynes Manual that I have for the vehicle.
Timing Belt Crankshaft Bolt 116-123 ft lbs
