1989 Mazda b2200 Oil Leak
1989 MAZDA B2200
129,400 MILES • 4 CYL • 2WD • MANUAL
TUBAJOHN
I recently purchased an 89 B2200 SE5. It has a 5 spd manual transmission. After I got it home I noticed a pretty severe oil leak on the engine guard under the main pulley. I pulled the fan, pulleys, and timing chain cover off. There was no oil on the timing belt or noticeable oil at the bottom of the crank pulley. After cleaning everything up an driving it a few miles. There was oil agin on the engine guard in the same place. The truck runs very good and when I check the engine oil level it has not gone down. Any ideas?
Thanks
Nov 9, 2010 at 8:27 AM
DOCFIXIT
  • 18,828 POSTS
Check out oil pressure switch right side engine near oil filter
Nov 9, 2010 at 10:10 AM
TUBAJOHN
Thanks for the tip I looked at that this morning but the oil pressure switch is clean. However, I think I found a small 1/4 inch v shaped crack right at the center of the front of the block where the middle screw of the oil pan goes in. Now if I can just repair the crack. Any suggestions?
Nov 9, 2010 at 11:35 AM
