fuel filter location
1988 MAZDA B2200
LISA GOMARD
Engine Performance problem 4 cyl Two Wheel Drive Automatic 160000 miles
This is in the category that the truck stalls while driving it. It will just die. Then if you sit there for about 2 minutes & start it up it will start again. Wanted to check the filter but don't know where it is located & can't seem to locate the fuel pump either. Could you tell me where they are located & if they could be causing the problem I printed out your probable causes for this & will try them when I get home today. Is the fuel filter & pump in the gas tank?
Thank you!
Oct 3, 2008 at 3:20 PM
ASL3762
  • 6 POSTS
if it fuel injected it is in the tank, an if it is carbarated the fuel pump is on the back side of the motor
Oct 15, 2008 at 1:12 AM
RICKYBOBBY2119
When you say back of engine do you mean on the firewall?
Jan 13, 2017 at 11:15 AM
No, it will be on the rear of the cylinder head if it is has a carburetor. Manual trans is on the back of the head.... Auto is in the fuel tank. No FI in 1988.
Jan 18, 2017 at 4:58 AM
