1988 Mazda b2200 Blinkers wont work
1988 MAZDA B2200
22,300 MILES • 4 CYL • 2WD • MANUAL
TIRBECA
My boyfriend has an 88 Mazda B2200 truck and the blinkers wont work. The hazards work, and all the side markers work, but when you try to use blinkers, nothing happens. He has a "rigged" wiring harness for a tow hitch, but other then that all the electrical checks out. What do we do?
Jul 16, 2010 at 3:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first check fuse if OK check signal flasher relay. if OK as well then check for power getting to the turn signal switch.
Jul 17, 2010 at 12:10 AM
TIRBECA
We have replaced the fuses and relays already, and there is power to the switch because its the same switch as the brights, and they work just fine..
Jul 17, 2010 at 12:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
signal switch must be faulty then if all above was checked good.
Jul 18, 2010 at 11:05 AM
