I am disassembling the engine to replace the head gasket. I have been following the repair manual instructions and am now at the part where it states to remove the exhaust manifold.
I've unfastened the two bolts which connect two metal tubes between the carburetor and the exhaust pipe, and there is a third metal carb tube connected to the top of the exhaust manifold that leads to four smaller tubes.
Unfastening the nuts for these small metal tubes doesn't seem to loosen anything, and a wrench won't fit to reach the inner nuts positioned underneath the heat shield on each metal tube.
It doesn't appear possible to remove the heat shield without first removing the metal tubes, and this is the problem I'm encountering. This part is not described in the manual, and I'm not sure how to proceed.
Aug 24, 2023 at 9:36 PM
