Where is the water pump located and how to I replace it?
1995 MAZDA 929
177,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOMDRAY315
MEMBER
1 POST
FOLLOW
Dec 15, 2007 at 4:19 PM
BLACKOP555
CERTIFIED EXPERT
pump is located in the serpentine belt assembly, you will see hoses going into it
Dec 15, 2007 at 8:04 PM
CERTIFIED EXPERT
The water pump is behind the timing belt cover and you will need to remove the timing belt as well so you might as well replace it. Check out the images (below). Let us know if you need anything else.
