1995 Mazda 929 Gasket Oil Leak
1995 MAZDA 929
74,800 MILES • 6 CYL • AWD • AUTOMATIC
BHADRAMKODAKO
I recently bought a 1995 Mazda 929. I took it to a near by Firestone for a complete vehicle inspection. They said, The Gasket Oil is leaking. They actually shown me the leak, its not dropping anything but its becoming wet and I can see the oil is leaking somewhere on the upper Gasket. They recommended to replace the Gasket to fix the leakage. I need your suggestion if it is a major issue that needs to be fixed immediately or Is it normal in used cars of that old, so I can wait until I see the leakage drops on the floor. Please advise.
Dec 7, 2008 at 6:25 PM
EUGENE123
  • 273 POSTS
this is really up two you but i can give you some advice, if the gasket keeps leaking and you don't want to fix it right now just keep an eye on your oil and make sure you keep it full and the car will run fine, but keep in mind your going to keep adding oil until you replace the gasket so its really up to you ;) if you have any more questions please ask
Mar 29, 2009 at 10:24 PM
