My 929 is now misfiring and often shaking when at idle. I found the reason when I replaced the spark plugs. Two were wet with oil, and two I couldn't replace because they were stuck.
How much do you think it would cost to open the engine and replace the gaskets/seals leading to the
spark plug wells ? Would this be classfiied as an engine overhaul ?
Thanks !
Thanks !
Aug 30, 2010 at 7:58 AM
