I have a Madza 929 with 70,000 miles on it. The car had sat for time and was not driven. When I bought the car I replace the time belt first off, then I had to replace two Hydraulic Lash Adjusters in the right side of the motor. After carefully disassembling and labeling each parts I reasemble the head putting all parts back into their place. Line up all the timimg marks. Tried to chank the car it would crank up and cut back off if you tried to crank it again it the car would flood out. I went back into the car to check the timing it seem to be alright I even asked a high school class mate of mind that work as a mechanic for the Madza dealer ship for a number of years to look at it. And he said the car was in time. He suggested that I change the fuel pump relay connector in the relay box. I did that and tried to crank the car agin it crank up cut back off. Other items I chance Battery new, Battery cables in good condition. Distributor Cap, Fuel Filter,Wireset, Spark Plugs all new. Starter, Alternator rebuild. Fuel Filter new,Throttle Sensor new. EGR Valve checked I even preform the flashlight test on the EGR Valve and I could not see the light. I've also replace the water temperature sensor in the intake and the one by the heater inside the car. I've also check the firing order a number time and it is correct according to my alldata computer program. The rotor is also new as well. Need some help bad.
Nov 18, 2009 at 11:52 AM
