mazda 626 V6 2001 - windshield wiper system
2001 MAZDA 626
STEVED
well I really screwed up...
the driver's side windshield washer was losing pressure (passenger side OK), to the point it was only spitting a few drops with each wash
i went to a mazda dealership and the service rep's suggestion was to "stick a pin into the holes and wiggle it around to clean out the dirt that's probably there"
well, i did, and it helped a bit. but then 1 of the 2 holes was pointing in the wrong direction. so i tried to angle it and SNAP - the pin broke!
now i have 1 of the 2 holes in the "jet thingy" blocked. i suspect i need to replace that whole "jet" (the thing on the hood). is is possible to get JUST that part, or will i end up having to replace the whole washer system, or hood, or ???
thanks in advance
Dec 10, 2006 at 11:09 AM
COSMO
  • 347 POSTS
No No No....you can buy the washer nozzles separate. You will not have to replace anything other than the washer niozzle itself.
They detach from the underside of the hood.
Good Luck
Cosmo...Mazda Tech
Dec 10, 2006 at 10:06 PM
