Mazda 626 2002
2002 MAZDA 626
COLETTE MILLER
Spark plugs and wires were changed 3 months ago.....check engine light came on and car was stalling and would hesitate...took to autozone and they checked with instrument under dash....code read "misfiring"....checked gapping.......ran fine....then stopped running.....changed spark plugs to pregapped plugs....(expensive).....checked wiring....car will start and drive briefly, but will stall, stop and not restart......checked coil pack and car started, stalled and will not restart....also found oil on second plug and looked a little burnt....what could be the problem?
May 1, 2006 at 10:42 AM
LOSONE
  • 1,616 POSTS
It cold be a fuel problem. Have you checked the injectors to see if they are all "clicking" the same? DON'T use zone or other cheap wires on that engine. Use good solid parts not discount parts.
May 1, 2006 at 2:19 PM
