I just picked up a 1995 Mazda 626 Cronos, 4 door, 4 cylinder, 2 litre engine, automatic. Great little car. It has a little problem starting in the mornings it stalls, sometimes 2 or 3 times. It will also stall sometimes at intersections. Doesn't matter if it's cold or up to temp. Not really all that concerned about this because I'm sure it's something like the MAF or Temp sensor, but what has me puzzled is this. We went to connect to a diagnostic and it wouldn't. The diagnostic, while a little older is a good one, but would not connect. No problem, just get the Hanes manual out and jump the two pins, count the times the light flashes and read the code, right ? Wrong. Went to jump the pins and noticed the # 10 pin is missing. Supposed to jump to ground to activate, but it's not there. I took a quick look, it's not like its broken or shoved down in, it is simply missing. There doesn't seem to be a wire for it either. It looks all original, though I wouldn't know for sure. What does this mean.
Oct 16, 2007 at 11:39 AM
