2002 Mazda 626 water leak in driver's side floor
2002 MAZDA 626
64,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALLSOP
I have noticed water pooling on the driver's side floor of our Mazda recently. It only seems to get wet when it rains and for the most part only while I'm driving in the rain. I've also noticed that the moisture is coming up through the carpet in the floor as the carpet under the floor mat will be wet but the top of the floor mat will be dry.
The trouble spot seems to be centered in the middle of the driver's side floor. Each time the floor has been wet the carpet along the sides and above and below have been dry. Only the middle of the floor board gets wet.
I thought the moisture may be coming from the AC but I have run the AC quite a bit on dry days and had no problems with water on those days.
Do you have any ideas what may be causing this or where the water is getting in? Has anyone else had this problem before either?
Any help would be appreciated.
May 16, 2008 at 6:35 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
have the underside of the car checked for any floor plugs or defects in the floor pan.
Mark (mhpautos)
May 16, 2008 at 6:41 AM
JRZYSHELLEY
Please read my response for the 2006 Miata and you will learn about the problems with Mazda's drainage systems which are known to be defective in some of their models.
Jun 26, 2014 at 1:16 PM
LATASHA NOTEARSLOST BOYD
I have a 2002 mazda 626 lx 2.0L my car is leaking water from somewhere under the front driver side. Does anybody have any idea of what this might be? Please HELP
May 16, 2016 at 11:21 AM
