2002 Mazda 626 Driver door problem
2002 MAZDA 626
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
GERONIMO1885
Last week my fiance opened driver's door to get in and a screw hit the ground and after closing door it will not open....by comparing the screw to passenger door, I can tell that it is one of the 3 screws that secure the latch assembly on door...problem: how can I get the door open to work on it? The interior door panel screws (plastic) can only be accessed with door open. Any ideas? Thks
Jul 14, 2008 at 1:39 PM
KHLOW2008
  • 41,814 POSTS
hi geronimo1885,
This is going to be tricky and hope my suggestion works.
The latch is now loose so the openers are not pushing or pulling far enough to get it to open.
Remove the inner opener assy and pull the wire by hand, it would give you more clearance.
Jul 14, 2008 at 1:55 PM
GERONIMO1885
Thks...will give that a try...Rich
Jul 14, 2008 at 2:23 PM
