The car wont go into gear in drive, unless i turn overdrive off. if i put the shifter in 1 or 2 it will engage. now with overdrive off, it will shift 1, 2, 3. and if i going around 30+ mph and turn the overdrive on, it will shift into overdrive and run fine until i come to a stop. i cannot find any information on this. any ideas? i checked the TCM for codes. only had p0733. i checked the fluid and the level is good. i tried starting the car in every gear to check the range sensor. and it only started in p or n. i know a transmission guy will know right away. lol
Mar 25, 2019 at 5:16 PM
