Thermostat
2000 MAZDA 626
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
ECKDAR
The car is overheating and we think it is the thermostat. do you know where it is? the upper radiator hose looks like it goes right into the intake and the lower one goes up into the engine under the coil pack
Jun 12, 2009 at 6:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It's in lower radiator hose..you will have to remove the coil to gain access. Here is a guide that will walk your through the repair with diagrams below to show you how on your car.
Jun 12, 2009 at 7:32 PM
MMOTTRAM
The car is over heating. Our mechanic said that we need to replace the thermostat. They are charging way too much money and we want to replace it our selves. However, we do not know how to locate it. Can you provide a drawing and easy instruction on how the replce this part?
Aug 17, 2019 at 2:30 PM (Merged)
If you follow the upper radiator hose to the engine, it should lead you to the thermostat housing. If it doesn't, let me know what engine you have.
MWLED500
Where is the thermostat located on a 2.5L engine?
2.5L ENGINE
Follow the radiator bottom hose to the engine-You have to remove the aircleaner to get to it
