my 626 has no brake lights, it keeps blowing the fuses (15amp), took it to a panel beater a while ago to fix the boot as somone smashed into it. all the lights worked except they put a 30amp fuse in the slot to stop the fuses from blowing. doing that caused the wires to the brake light switch to melt. i changed the wires and fuse, found the brake light switch is blown so changed that as well. now its still not working so i believe wires in the wiring loom are melted as well but since taking it out and finding there all ok im out of options. if anyone has any ideas on what else to check i would love to hear them. i have even tried by passing the wires and adding in new but found it still dose not work.
May 2, 2008 at 3:25 AM
