2000 Mazda 626 Cracked boots on universal joints
2000 MAZDA 626
114,000 MILES • 6 CYL • FWD • MANUAL
AKAKAK
  • 6 POSTS
Was looking under car to solve rattle. Solved rattle but found another issue. Rubber boot near front left tire is cracked in half, is leaking oil. Front right has same issue but less severe. Do I only need rubber boots or do I need new universal joints? How much should it cost?
Aug 7, 2010 at 7:11 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
At this stage you should only have to do the boots as if the grease is still in the CV's they should still be ok, the boots are only around $20.00 and you may only be looking at a 2 hr job + the replacement grease, check your local labour rates.
mark (mhpautos)
Aug 8, 2010 at 6:07 AM
AKAKAK
  • 6 POSTS
thanks for the free advice! i had confidence going in. i ended up having more problems then i thought and ended up needing 2 new axles, 2 new rotors, and 2 new break pads, but i left the place only paying $450 so i think it was okay.
i'll use this service in the futre and try and donate.
Aug 14, 2010 at 12:59 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I am pleased that you had a good result, that price you paid is good value for money, thank you for using 2carpros, you feed back is always welcome.
mark (mhpautos)
Aug 14, 2010 at 5:51 PM
