1999 Mazda 626 cooling fans
1999 MAZDA 626
G.RICHARDSON21
Engine Cooling problem
1999 Mazda 626 6 cyl Front Wheel Drive Automatic 160k miles
The cooling fans will not come on when required. I know they work because I disconnected them from thier plug-in and connected them directly to the battery. They did run. There must be a sensor that is not working is my guess. The temp gauge does work. Any thoughts on what is going on?
Sep 15, 2010 at 4:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Check your fuses and the cooling fan relay, if they are good than the PCM is probably at fault since it runs the fan, not a sensor.
Sep 15, 2010 at 4:56 PM
G.RICHARDSON21
PCM??
Sep 16, 2010 at 1:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
PCM stands for powertrain control module and acts as the main computer for the vehicle.
Sep 17, 2010 at 12:23 PM
