1998 Mazda 626 oil burning engine
1998 MAZDA 626
110,000 MILES • 4 CYL • FWD • MANUAL
MAZDALOVER
engine burns oil when cold , stops burning when hot, will new piston rings cure problem ...???thanks
Dec 16, 2007 at 9:06 AM
JUSTIN FREED
  • 87 POSTS
Maybe, but you need to make sure it's the rings and not something else before you start tearing off the head, etc.
With your engine cold, pull out a spark plug and do a compression check. Then, squirt some oil in the cylinder and redo the check. If your compression goes up significantly, there is a good chance that you have worn rings.
If it is the rings, maybe you could try throwing in a can of motor honey etc. This IS NOT a fix but might get your car to go a bit further before you have to tear into it.
Dec 16, 2007 at 9:26 AM
