Your low and high beams are off the same bulb. It has dual filaments inside the bulb. I have seen that both low beams burned out.
I would remove the bulbs, one at a time, and test them. Your bulb has 3 prongs. Use jumpers wires, connect two prongs to the battery. If the bulb is good, you will have light in two of the three combination (Prong 1 prong 2, prong 1 prong 3, prong 2 prong 3). If you only have 1 combination, replace the bulb.
Nov 11, 2008 at 6:35 PM
