My car would crank but not start. I took it to two repair centres and they checked it. 1 said the oil leak caused the crank shaft sensor to go bad and that is causing the problem. the other said the oil leak is a problem and the EGR valve and air mass meter boot are giving error codes. I got the oil leak fixed. Car started, got it back but now after a week the same thing happens, cranks but will not start
What should I do? Replacing the EGR valve is expensive..Crank shaft sensor does not give an error code.
I'm a student and do not have a job. I need help !
Oct 3, 2009 at 12:24 AM
