1998 Mazda 626 Engine dies when pressing clutch
1998 MAZDA 626
120,000 MILES • 4 CYL • FWD • MANUAL
FDQX
  • 41 POSTS
The engine was replaced with a 30000ml driven one and after that the problems started. Only the basic engine is new, manifolds and supplements are from the original engine. Spark plugs and timing belt were changed when new engine was installed.
The engine sometimes dies when pressing the clutch down. When pressing the clutch pedal, RPM quickly goes near the 0 line; if the engine doesn't die, the RPM will rise back immediately to 1250rpm (idle is 750rpm). While car is on move, the RPM is 1250 and drops to 750only when stopped and waited a couple of seconds. If you let off the clutch pedal when RPM is going down, it immediately rises back.
If the engine dies, it restarts well.
It also feels like the the clutch pedal "attacks" your foot when accelerating and shifting gears. The car has clutch replacement done with the engine replacement
When headlights are on, the RPM drops easier to the 0 line.
Sometimes the car works a few days just fine, but usually is a pain to drive.
It used to have a diagnostic code for camshaft position sensor malfunction, but doesn't do it anymore; the sensor is replaced. The new sensor has touched the camshaft pulleyl and is now on with a self-made cardboard gasket that prevents it to touch the pulley.
The diagnostic code that it gives now is "Battery voltage under 8V". The alternator and battery have been checked, also the wires from PCM. The voltage has been correct everytime measured.
The car vibrates like an earthquake to inside when at idle. The idle rpm stays steadily at 750. The power steering/AC belt makes a whining noise that gets worse when RPM increases. The belt has been checked.
So far replaced:
IAC motor/valve
Spark plugs, plug wires
Fuel injectors
Camshaft position sensor and its' connector
Battery
Intake Manifold gasket
Air filter
Fuel pressure regulator
EGR valve
The bottom of ignition lock
Cleaned:
EGR and IAC valves
Throttle body
Mass airflow sensor
Checked and tested to be proven OK:
PCM
Wires from PCM to alternator and Camshaft position sensor
Leaks everywhere
Ground connections
Timing belt installation and other belts
Every fuse and fuse boxes.
Battery terminals
After the installation both seat heater elements as well as the blower element died. Had to replace the blower element with new one.
Everything should work fine, but doesn't. What could it be any more? I've already spent four months and around $1500 on three different mechanics (including a Mazda dealership, the workshop that replaced the engine and a car electrical repair shop) who haven't found anything.
Dec 23, 2008 at 7:14 AM
JAMES W.
  • 2,394 POSTS
WOW, it sounds like you have changed everything but the insides of the muffler. From your description, the vehicle is definitely searching for idle. Looking at your wiring diagrams, an eratic signal from the crankshaft position sensor would make the IAC wander in it's position. The CPS output could fluctuate and still not be picked up by the ECM. Either that, or the ECM is not processing the inputs correctly.
Jan 10, 2009 at 5:46 PM
FDQX
  • 41 POSTS
What is the role of Camshaft position sensor in the idle process? The self-made cardboard gasket between the sensor and the cylinder head cover seems to prevent the RPM to drop below 750 (dropped only a few times below that since the gasket was installed), though all the other problems are still there and the engine still searches the idle for a moment before finding it.
Every time the car has worked well for even a moment, it had involved the re-installation on the CMP (cam sensor). Feels like the engine just loses the correct information very quickly.
Crankshaft position sensor doesn't give any malfunction code, and as far as i know the car shouldn't even start if it has a malfunction?
Jan 12, 2009 at 5:55 AM
JAMES W.
  • 2,394 POSTS
I've tried to find the air gap specs for the cam sensor, but my system only shows it for the crank sensor. Lets look "outside the box" for a little bit. A vacuum leak in the intake area will cause the same problem you describe, ie stalling, searching idle etc. If you spray down the intake area with a can of ordinary carb cleaner and hit a vacuum leak, the engine rpms will immediately jump up and then, start to search again.
Jan 12, 2009 at 1:21 PM
FDQX
  • 41 POSTS
Seems to be impossible to find the air gap specs for the cam sensor; I managed to get the importer's workshop manual sometime ago, but it doesn't tell it either. Maybe the valve head cover is just designed like it can be in only one position. When I take the sensor off and put it back, it can move vertically around 2 to 3 millimetres before the bolt is tightened.
I've sprayed the whole engine bay and every hose and gasket with brake cleaner several times to find the leak, but there doesn't seem to be any.
The dealership mechanics last time told me that the problem is likely the ECM, though they tested it and it was OK. And I can't believe that the ECM/PCM can go broken when installing the new engine - everything worked well before the installation; the old engine just leaked so much oil that it was cheaper to replace the whole engine than rebuild the old one.
I'm taking the car to the workshop for the last time next tuesday; The dealer's in the neighbor town has more experienced mechanics so let them give a try; if they can't find anything, no one can. Let's see what happens.
Thanks for the comments, I'll attach them to the list of things already done for the mechanic.
Jan 12, 2009 at 3:36 PM
JAMES W.
  • 2,394 POSTS
Let me know what you find.
Jan 12, 2009 at 5:19 PM
FDQX
  • 41 POSTS
The problem changed it's nature.
Though the alternator was tested in the other three places, it turned out to be on it's end. With all electrics on the voltage dropped to under 8V in about a minute.
The 80A alternator was replaced with new 90A one, which was tested with the full load after installation.
The RPM now behaves like it should in normal driving.
The virbation was gone for half a day, but now it's back, maybe it's even worse.
It also seems that the NEW alternator/engine can't take the load. When I have AC, rear window heater and lights on at the same time, the battery light in dashboard turns on and won't go away even if i turn the electircs off. I have to restart the car when it appars to get rid of it. The headlights appear brighter when I hit gas pedal and when back to idle, they darken.
What on earth can screw the car's electronics like that? The sensors were all OK, they were tested today as well. I think the car's system should be able to handle headlights, AC and rear window heater at the same time. When I turn any of those on, the RPM drops quite a lot for a while, it almost sounds like the car is going to die, but it doesn't
Jan 20, 2009 at 11:22 AM
FDQX
  • 41 POSTS
I self-tested the behavior of the car with different electric devices on. I noted that only high-power device that did NOT affect much to the idle rpm and alternator light was the stereo system which i have installed ages ago. It has separate wiring, so can it be somewhere in the car's original wiring? It's weird though that as far as i checked the wiring diagrams, the rear defogger, headlights and ac system do not have common groundin points (if i understood it correctly). Where should i look? I already checked the wire connections in the main fuse box and the area near it, as far as i could see the wires before they disappear in the plastic covering.
Jan 20, 2009 at 1:30 PM
JAMES W.
  • 2,394 POSTS
When you mentioned you have an aftermarket stereo system, the alarms went off in my head. Not saying this is your problem, but a couple 'a weeks ago, I worked with a guy, online, with an older firebird who kept burning out alternators. After about a week of dialoge back and forth, he mentioned he had an aftermarket stereo in the car with a 1,000 watt amplifier. The rest is history.
Anyway, lets try a little experiment. With "all" your accessories on, including radio and engine at idle, check the voltage at the battery. Then, turn the loads off one at a time. Each time you turn off a load, record the battery voltage rise, and what you turned off. A digital volt meter will give you readings in fractions of a volt which will be more accurate. Also, a 90 amp alternator, nowadays, is not oversized. Granted, the car may have come from the factory with an 80, but that's still plenty small. One more thought, when you had the engine changed, did they install the original crankshaft drive pulley on the new engine?
Jan 20, 2009 at 5:16 PM
FDQX
  • 41 POSTS
I can't believe that the stereo system could be the cause; the system was installed months before the engine change and it didn't cause any problems. When the engine was installed, the stereo system power cable wasn't connected to the battery - i connected the cable back about a month after the engine swap, the porblems started immediately after the engine change. My amp is only 300 watts, and I've used it in my second car for ages with similar installation with no problems before this car. The amp is OK, i tested it on my other car and it caused no problems. The amp is now disconnected, but it doesn't change anything. I've even tried to get the whole radio off the dash to rule out mistakes in stereo installation, and came to the conclusion the stereo is installed correctly.
About the crankshaft pulley, I actually don't know. I bet the mechanic doesn't remember it either.
I take it to the workshop on friday, we try another alternator just in case this one has failed. I make sure all the correct voltage measurements will be done.
The alternator that is there now, was measured with the car's diagnostic system. The voltage was over 15V (seems a bit high to me) without a load and about 14,6V with the full load including all the electronics on the car that can be turned on.
Can the ECU be damaged? Does the ECU determine the electrical load or is there a separate detector?
Jan 21, 2009 at 2:22 AM
JAMES W.
  • 2,394 POSTS
Was this a used motor you had installed? The reason I asked about the crank pulley is there are different sizes for different motor installations. If your alternator isn't turning fast enough, it will cause the problem you describe. Not that this is the problem, but it's a possibility. I really don't believe it's the radio either, per your description, everything points to alternator. Let me know what you find.
Jan 21, 2009 at 9:32 PM
FDQX
  • 41 POSTS
The engine was 30000 miles driven when i bought it.
The new alternator is now installed. Worked like an angel for a few hours, then started to vibrate like an earthquake again when at idle. When either rear defog or ac is on, the headlights (and all the other lights like dash illuminations, indoor lights and such) brighten when hitting gas and dim on idle. The stereo unit illumination is the only light that doesn't react the RPM.
The AC on without other electronic makes the car vibrate.
The car is now pretty good to drive though; sometimes when coming to a stop and the clutch is pressed, the RPM goes near the 0 line for a while, but not often. If all electronics are on, it does it more often. Usually the combination rear defog + headlights lets the RPM go too low for a moment before the car "finds" the correct RPM.
I also noticed that if you get the RPM really high (over 6000) when not moving, and then let off the gas, the vibration sometimes doesn't come back when returning to idle.
I think it really is a problem with electronics, but the alternator doesn't seem to be the whole truth. I can't believe that the car was desinged the way that you can't have rear defog and headlights on at the same time when driving in the city.
Jan 23, 2009 at 9:56 AM
FDQX
  • 41 POSTS
Can the alternator supplement be failing, like is there a possibility that a faulty belt tensioner or pulley could cause this?
Yesterday I had the battery negative terminal off for a couple of minutes. I put it back and the RPM started to missbehave like before. I can't imagine any solution to that, or could it be the PCM?
Jan 26, 2009 at 5:34 AM
FDQX
  • 41 POSTS
I wrote a list of everything that has been done and decided to translate it to english too.
I looked my receipts and found out that the search of the problem has costed me 1800 euros which is way over $2000. At the moment it has costed as much as the engine and it's installation have cost.
The xx.x numbers are dates (day/month), I use European standard for them.
Symptoms:
1) Clutch pressed; RPM ->almost to 0->over 1000->750 only when stopped
2) Vibration at idle. Sometimes doesn’t vibrate when started cold, but after driving a mile it sure does. The nature of the vibration depends on the electrical load.
3) Some belt makes whining noise; gets worse with RPM to a certain point when it stops.
4) The clutch pedal feels like it attacks the foot when letting go.
5) (Long distance)headlights dim at idle, especially with the rear defroster on.
6) The gas pedal doesn’t seem to react correctly when RPM is under 2000
7) The ignition sometimes doesn’t stop right after pulling the key out.
8) Malfunction codes: 0340 (not anymore), 1632, 1631.
Shop 1= The shop that changed the engine
Shop 2= Mazda dealer #1
Shop 3= Car electrical repair shop
Shop 4= Mazda dealer #2
20.8
Engine changed: Only the basic engine is new, the valve head cover and camshaft position sensor, as well as the supplements and manifolds are from the old engine.
22.8
Stalls for the first time (clutch pedal pressed when slowing down)
25.8
Shop 1
Changed Idle control motor, battery and motor grounding checked, throttle body cleaned
Shop 2
New ignition lock bottom ordered, so the car will start for sure when it stalls.
Noticed the vibration inside the car when at idle.
Air filter changed.
8.9
Shop 1
Changed ignition lock bottom and spark plugs .
3.10
Shop 2
Nothing found, negative battery terminal changed. Diagnostic codes 0340 (Camshaft sensor) and 1632 (Battery voltage low) Intake manifold gasket and vacuum hoses checked.
Stereo installation removed to determine if that was the cause. It wasn’t
5.10
The last time it has stalled when driving.
6.10
Shop 2
New Camshaft position sensor. Still gives the malfunction code.
8.10
New battery purchased
9.10
Stereo installations back – doesn’t change anything.
24.10
Shop 1
Timing belt checked, valve head cover gasket replaced
25.10
Shop 1
Changed camshaft pulleys from the old engine. RPM still misbehaved, but didn’t go under 750 for a few days. Symptom #4 went off for a few days too.
1.11
RPM started to go below 750.
24.11
Shop 2
Camshaft sensor connector. The malfunction code 0340 hasn’t appeared after that. Code1632 (Voltage) Still appears. Worked fine for a short test drive like after the pulley change. Next ignition and the problems came back.
9.12
Shop 1
Wiring from PCM to the CMP sensor checked, OK.
12.12
Shop 2
PCM Checked->OK, PCM to Alternator connection checked. Code 1632 still (Voltage)
The company who sold me the motor and the service manager talked about the thing over the phone and came to the conclusion that the engine should work OK, though the engine is imported from Japan.
23.12
Shop 3
Idle RPM raised to 1000. Didn’t help, the vibration got worse. I hoped they’d check the electronics but they claimed the problem wasn’t electrical
9.1
Korjaamo 3
IAC valve cleaned, idle RPM changed back to 750
Shop 4
EGR valve, fuel injectors and fuel pressure regulator changed.
9.1-13.1
Tried valve cleaner and injector cleaner with gasoline. No change. Noticed that the CMP sensor touched the camshaft pulley. Raised a bit with a cardboard gasket.
16.1
Shop 1
New ground terminal, wire and grounding point to the battery.
20.1
Shop 4
The alternator failed. 90A Alternator changed. Every symptom was gone. Idle speed adjusted with tester. No malfunction code after change. Before change code 1631 (PCM failed from over 20V voltage). 90A alternator was the only one that didn’t cause the whining noise.
Later that day the symptoms came back. RPM still behaved right, but the others appeared again. The alternator light came on.
22.1
Bought NEW alternator
23.1
Shop 4
New alt. installed. Everything worked fine for a few hours
I drove about 60 miles on freeway and when i came back to the city, the symptoms came back.
PCV-valve checked, it was OK
Jan 27, 2009 at 1:25 PM
