1997 Mazda 626 no fuel pressure
1997 MAZDA 626
97WHITERAM
Engine Mechanical problem
1997 Mazda 626 4 cyl Front Wheel Drive Automatic
engine wont start. has spark, timing correct. no fuel pressure. turned key to on position, pump does not engage. cranked engine, does not engage. turn key to off. pump engages for 2-3 seconds. dropped tank and tried another pump, same result. diagnostic tool showed no codes. not sure where to proceed. pump relay or intake problems ? some books call it a MAP sensor, others call it something else. are there any physical test procedures I can do to isolate the problem ?
Oct 9, 2010 at 11:41 AM
Inspect and test the main relay and fuel pump relay-if both okay-check the computer control of the fuel pump relay circuit
Oct 9, 2010 at 2:58 PM
