1997 Mazda 626 no cranking
1997 MAZDA 626
11,800 MILES • 6 CYL • FWD • AUTOMATIC
BKANTHONY
Hi guys how r u? I have a 97 mazda 626 that will not crank wen i attempt to start it. I have full electrical power....headlights, interior, radio, dash lights..etc yet when i turn the key i get no crank. the battery is good the wires are good terminals clean fuses good distributor cap n wires good not sure what it can be would u guys have sum ideas 4 me thanks alot if ur able to answer.
Jul 19, 2010 at 11:53 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will have to check for power at the starter solenoid, there should be 12V when key is on crank and there should be constant 12V at the main cable, if you have power as above, the starter is faulty, if no power at the solenoid, you may have a problem with the transmission isolator or even a faulty ignition switch, start here.
Mark (mhpautos)
Jul 20, 2010 at 1:10 AM
