1997 Mazda 626 misfire when at normal operating temp
1997 MAZDA 626
276,000 MILES • 4 CYL • FWD • MANUAL
NIKKI1965
vehicle runs and drives brilliantly wen cold, once the engine comes up to normal operating temp it creates a misfire under a load at low rpm. above 2000 rpm there is no misfire and the engine does not struggle at all. if the engine is under a load at low rpm and the throttle is opened all the way it will backfire through the throttle body and air box. Im thinking an electrical component is at fault because of the heat factor and i suspect coil packs as it is a ditributorless motor. The engine light has not come on. Is anybody familier with this problem?
Jun 15, 2009 at 3:43 AM
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jun 15, 2009 at 5:13 AM
