1997 Mazda 626 Gear Shift Stuck
1997 MAZDA 626
MICHELLE1119
Transmission problem
1997 Mazda 626 4 cyl Automatic
The button on the side of the gear shift is stuck. Usually I have to depress the brake, press the side of the gear locator, and pull the gear locator into the reverse position. The button is stuck and locked. I cannot push the button in to move the locator. Please help me!!
Jun 20, 2008 at 4:02 PM
KHLOW2008
  • 41,814 POSTS
Hi michelle1119,
Check if the brake lights are working when you press the brake pedal.
If they are not working, you would not be able to shift out of park, except with manually releasing of the shift lock.
Check for a blown brake fuse or faulty brake switch.
Jun 22, 2008 at 11:47 AM
