1997 Mazda 626 Car will not crank
1997 MAZDA 626
198,000 MILES • 4 CYL • 2WD • MANUAL
BWRENN7237
Hi, My car has been missing pretty bad. After about a month I got into my car to go somewhere and it would not crank. My husband replaced the distributor thinking that would fix the problem but the car will still not crank. Do you have any suggestions? it seems to be running the battery down when we try to crank it now too.
Feb 7, 2009 at 11:42 AM
F4I_GUY
  • 3,302 POSTS
Well the battery is dying down because you keep on trying to crank the vehicle.
If the vehicle is indeed cranking over but not starting you must check for proper fuel pressure and good start spark.
Feb 8, 2009 at 3:14 PM
KHLOW2008
  • 41,814 POSTS
Hi bwrenn7237,
Thank you for the donation.
Check the following link and see if you can come up with something for us to continue with.
https://www.2carpros.com/kpages/first_things.htm
Feb 9, 2009 at 7:20 AM
