1996 Mazda 626 2 problems
1996 MAZDA 626
CLEROUX17
1996 Mazda 626 6 cyl Automatic
ok i have a weird problem going on with my mazda. i dont know much at all about cars but dont want to spend a whole lot of money fixing it since its on its way out. anyway the other day i had my lights on, pulled inthe garage turned them and everything off for a couple of hours..when i went back out to the car the lights would not come back on...the brights come on only if you pull back on the light switch thing but if you push it forward to leave the brights on those dont work either so now i have to hold the light switch back when i drive at night so the brights are on..how could i fix this problem?
number 2---my air conditioner doesnt blow out cold air anymore...it blows air but its hot...do i just need to put that gas that comes in a can in it or do i need a lot more work...please help me
Jul 28, 2008 at 8:31 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would first be checking for a blown fuse and then a faulty relay for the headlights, as for the A/C you may well have a refrigerant leak, and if so the leak should be located & repaired before re charging the system.
Mark (mhpautos)
Jul 29, 2008 at 6:48 AM
