1995 Mazda 626 Pulley Bolt
1995 MAZDA 626
14,031 MILES • 6 CYL • 2WD • MANUAL
JENNAYBEE25
I am currently in the process of replacing the water pump in my mazda. I'm down the the pully where the timing belt is, then bolt on the pulley will not come loose. Have used air tools w/ up to 200 lbs of pressure, it doesn't show any sign of rust, what would you suggest to do?
Apr 5, 2009 at 8:32 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_296.jpg
which one ? crank pulley ! use a hammer and an old socket give it couple of good hits or I dont like it but use a bit of heat let it cool and try again
Apr 6, 2009 at 5:51 AM
