1994 Mazda 626 No Low-Beam Headlights
1994 MAZDA 626
18,200 MILES • 4 CYL • FWD • MANUAL
STEVEO-1
  • 10 POSTS
I have a headlight issue. Dashboard, parking lights, rear lights all run. Passing high-beam works when stalk is pulled. Bulbs are known good. No power to headlight bulbs w/switch on. Cannot find headlight relay to test. Have Chilton's manual, but wiring diagram does not match what I see on the car.
Have taken off cover for headlight switch on steering column, but that is as far as I got.
Jun 30, 2010 at 11:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
headlight relay is mounted on side of fuse/relay block, in engine compartment.
Jun 30, 2010 at 11:34 AM
STEVEO-1
  • 10 POSTS
I fixed by installing a new headlight circuit of my own.
Cost: $21.00.
I did not use the old circuit except to tap into a relay terminal in the right front corner of the car.
Otherwise, $347.28 for the headlight assembly, and/or $60.00 for a relay.
Jul 1, 2010 at 9:51 PM
