1993 Mazda 626 Low Idle on 93 626 2.0L , 5spd
1993 MAZDA 626
125,000 MILES • 4 CYL • FWD • MANUAL
BUSTER11
  • 8 POSTS
Car is idling low , base idle was reset at dealer about a year ago due to same problem , 5 min and 95 bucks , I read somewhere but can't remember where that it can be reset through the DLC by grounding a pin , if so which pin and where is the dlc on this car . Any help appreciated
Mar 24, 2008 at 11:42 PM
The DLC is on the drivers side near the power distribution box-jumper TEN and GND then adjust it see below-also do the computer relearn
https://www.2carpros.com/forum/automotive_pictures/12900_idle_speed_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_idle_speed_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_idle_relearning_1.jpg
Mar 25, 2008 at 6:58 AM
To: rasmataz
Posted: Tue Mar 25, 2008 8:20 am
Subject: 1993 Mazda 626 DLC / pin 10
Is the DLC under the dash or hood , are the pins numbered for easy ID or do you have a pic . Thanks
Its under the hood next to the power distribution box-it will show the pins under the cover
Mar 25, 2008 at 9:26 AM
MERLIN2021
  • 17,250 POSTS
Here's a good picture of the leads...and how to read trouble codes, you might want to do that first!
https://www.2carpros.com/forum/automotive_pictures/62217_Pre96OBD_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Pre96OBDCodess_1.jpg
Mar 25, 2008 at 4:02 PM
Where did you get that Mr. Merlin -the best thing I can do is give the 1993 MX6 info which I have one on hand 2.5 Liter- TYVM
Mar 25, 2008 at 5:42 PM
BUSTER11
  • 8 POSTS
The procedure you sent in your response for relearn drive is cut off for the manual transmission after the first line , can you include it please , also is the pin 10 grounding procedure done key on engine off .
Mar 25, 2008 at 11:18 PM
Yes its done with KOEO
https://www.2carpros.com/forum/automotive_pictures/12900_manual_tranny_1.jpg
Mar 26, 2008 at 6:28 AM
MERLIN2021
  • 17,250 POSTS
It's part of a program that came with my autotap OBDII scanner for my laptop...
Mar 27, 2008 at 2:29 AM
