1989 Mazda 626 Transmission wont go into gear
1989 MAZDA 626
MARLEECAR
Transmission problem
1989 Mazda 626 4 cyl Front Wheel Drive Automatic
While driving I used the hold feature on my 1989 Mazda 626 LX to down shift as I was approaching a stopsign. Suddenly, my car seemed to go out of gear and will not go into any gear I select. I ran a pressure check on the tranny line and I have no pressure. The RPM's will drop when I try to put it into gear, but it does not go into gear. The hold light is flashing. Any ideas???
Sep 3, 2010 at 7:35 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
If you have no line pressure i would be suspecting a faulty torque converter or a failed pump, i feel that you will have to pull the transmission and check this first.
mark (mhpautos)
Sep 5, 2010 at 3:54 AM
