the a/c fan works on position 1-3 but when you put it in position 4 it knocks the a/c out. What is wrong and how do you suggest it be corrected?
Aug 11, 2009 at 1:30 PM
PETECEFALU
MEMBER
i didn't want to donate to this question
Jan 20, 2012 at 11:44 PM
CERTIFIED EXPERT
So what is your car problem question-you don't have to if you don't want to-
Jan 20, 2012 at 11:54 PM
CADIEMAN
CERTIFIED EXPERT
youll need to replace the resister panel in the a/c case.
Jan 21, 2012 at 12:01 AM
PETECEFALU
MEMBER
here was my original question; Cooling Fan Problem
6 (6cyl) 3.0 ltr w 65,000 miles
the fan on my car runs well after the car is shut down and has never done this before. i was told the ect sensor may be bad. is that it or could itbe something else. also where here is it located on the engine? and how do i change it?
Jan 21, 2012 at 12:24 AM
PETECEFALU
MEMBER
i am looking for some instruction on how to change the ect sensor in my mazda 6
Jan 21, 2012 at 1:24 AM
RIVERMIKERAT
CERTIFIED EXPERT
The ECT is threaded into the engine block. It unthreads by turning counter-clockwise. Remove the electrical connector and unthread the sensor. Where the sensor is depends on what engine you have.
