2004 Mazda 6 Error Code 0051
2004 MAZDA 6
51,000 MILES • 4 CYL • FWD • AUTOMATIC
TZORZO
This car has had front damage mainly from radiator outwards, repaired.
Car idles roughly especially with air con on, I have had it to Mazda Service centre and they feel that it may be IAC valve or manifold, I have changed manifold not the IAC valve as yet. This valve has a crack in the plastoic moulding that carries the electrical connectors through to the valve, auto electrician does not feel that tthis contributes to cause.
I have unplugged the connector from valve, no change in idle problem??
Also where can I find a full list of error code s on the net?
Dec 22, 2009 at 3:49 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Here is the like to all std OBD11 code faults, you can check yours here,
https://www.2carpros.com/kpages/diagnostic_trouble_codes.htm
Your code P0051 is to do with the O2 sensor wiring, check that it was not damaged in the accident.
mark (mhpautos)
Dec 22, 2009 at 4:09 PM
