2003 Mazda 6 Shakes when in gear at stop light
2003 MAZDA 6
MJONAS
Shakes or Wobbles problem
2003 Mazda 6 6 cyl Front Wheel Drive Automatic
Getting a violent shake at the stop light when the car is suppose to be idling, it is "lunging" or jumping like the accelerator is being pressed. I have cleaned the MAF sensor, replaced the air filter and repaired a cracked air intake hose. The codes at Auto zone say really vague things, like fuel system pressure low (usually gas cap-was on tight), lean air/fuel mixture (ran injection cleaner through-runs better but still jumping). What could it be? Is there a throttle positioning sensor? Where should it be set?
Nov 30, 2009 at 10:00 AM
KHLOW2008
  • 41,814 POSTS
Hi mjonas,
Thank you for the donation.
Do you have the exact trouble code? That would enable us to understand the problem better.
From the symptom description, the idling speed is surging causing the problem.
Do you have any coolant losses issues?
Did you clean the IAC valve and throttle body?
Dec 1, 2009 at 8:48 AM
MJONAS
There is no coolant loss, and I have not cleaned anything but MAF and air filter (replaced). I read something that said to clean the EGR and throttle body (I will try these) but what is the IAC?
Dec 1, 2009 at 8:52 AM
KHLOW2008
  • 41,814 POSTS
IAC = Idle Air Control, located at throttle body.
Dec 1, 2009 at 9:13 AM
