2003 Mazda 6 Possible Throtte Body Issue
2003 MAZDA 6
111,000 MILES • 6 CYL • 2WD • MANUAL
CHRISBCREME1
I have a 2003 Mazda 6 V6 stick shift. For about 4-months now, almost every time i crank up the car, the rpms go up and down quickly at around 1000-1300 rpm. In addition to this, the TCS OFF Warning Light and Traction Warning Light light up. I took the car in and got the codes checked and there were a couple dealing with the throttle body.. Would it be possible that the throttle body needs just to be cleaned? Im hoping i dont have to replace the whole throttle body?
Also, while it is doing this issue, i cannot get above 30mph. I can change the gears from 1-5 fine, but will not go very fast.
If i floor the gas pedal, i can only get up to about 3000 rpm.
Also, for awhile, i could fix the issue by just recranking the car. Now it takes multiple cranks (many) and sometimes it depends on if the AC is on. However, now i cant get it to crank back normal anymore.
Please help!
Aug 23, 2010 at 9:03 AM
WRENCHTECH
  • 20,761 POSTS
What are the exact code numbers being set?
Aug 23, 2010 at 9:27 AM
CHRISBCREME1
When i did the diagnostic, they just told me that i needed to replace the throttlle body and that there were several codes dealing with the throttle body. Would you recommend i got to Autozone and get the exact codes?
Do you have any idea what the issue is based off what ive told you?
Thanks
Chris
Aug 23, 2010 at 9:42 AM
