This certainly is no bicycle, but I will post instructions and let you decide if you want to do the job.
Yes, calipers must be removed. Below are instructions for removal of your wheel bearings.
REMOVAL:
Remove or disconnect the following:
Wheels
ABS sensor
Halfshaft axle nut, unstake the nut prior to removal.
Brake caliper and rotor
Tie rod end from the knuckle
Damper fork-to-control arm bolt
Front lower control arm ball joints
Front upper arm ball joint
Wheel hub dust cover
Hub bolts and the hub
Hub using a press and Mazda tools 49 F026 10, 49 G033 102 and 49 G033 105. If the bearing inner race remains in the hub, grind a section of the bearing inner race until 0.02 inch (0.5mm) remains and use a chisel to remove it.
Snap ring
Bearing from the hub using a press and the tools illustrated
Brake dust shield, if it is being replaced. Mark the cover and knuckle for replacement purposes and use a chisel to remove the shield.
Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced.
((Exploded view of the front wheel bearing and knuckle assembly"”Mazda6))
((Use a press to remove the hub"”Mazda6 ))
((Use a press to remove the wheel bearing"”Mazda6))
INSTALLATION:
Using the tools illustrated, install a new dust shield cover assembly to the knuckle, if removed.
Using the tools illustrated, press a new wheel bearing into the knuckle assembly and install the snap ring.
Install or connect the following:
Wheel bearing retaining ring
Using the tools illustrated, press in the hub assembly.
Front upper arm ball joint and tighten the nut to 29-39 ft. lbs. (39-53 Nm)
Front lower arm ball joints and tighten the nuts to 122-147 ft. lbs. (166-200 Nm)
Damper fork bolt and tighten to 68-93 ft. lbs. (93-126 Nm)
Tie rod end to the knuckle and tighten the nut to 29-39 ft. lbs. (39-53 Nm) and install a new cotter pin
Halfshaft axle nut, tighten the nut to 173-202 ft. lbs. (235-274 Nm) and stake the nut
Wheels
Hope this helps..
Thanks for using 2carpros.com!
Jan 11, 2009 at 11:12 PM
