after my car has sat for a bit (overnight for example) when I start my car and leave for work it begins to severly shake after driving .5 miles. the shaking will stop as i tap the gas but after a few moments is shakes again. the shaking does however stop after driving it for approx. 1 mile (or 5 mins in Columbus traffic). last night i started the car and as it shook the dome lights began to dim- again until I pressed the gas. i then opened the hood and heard a sound that sounded like a tire or a ball that had a hole and was leaking air. So my ?? is alternator, vacuum line or worse????!!!?? Im not sure if i should continue to drive it until Sept 13 when I can afford to fix it because it only shakes during idle or should i be really concerned??
Aug 28, 2009 at 7:47 PM
