2007 Mazda 5 slips when raining and no adjustment visible
2007 MAZDA 5
62,317 MILES • 4 CYL • FWD • AUTOMATIC
HELLKINS
My a/c belt slips when it rains on the A/C compressor only. The belt goes from the a/c compressor to the main crank pulley and there is no visible adjustment that I can see. Do you know any way to adjust this belt?
Jun 11, 2010 at 10:24 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is a special tool require to install a new belt, there is no adjustment, if the belt is noisy, a new belt must be installed, you will have to get a dealer or a mechanic who has the special tool to do this.
mark (mhpautos)
Jun 11, 2010 at 10:32 AM
HELLKINS
What about shimming up the a/c compressor. there is a lot of threards left on the bolts that go into the bottom of the block. could i stack some washers of all equal size on the a/c compressor bolts to tightend the belt slightly. It only slps when it rains.
Jun 11, 2010 at 10:55 AM
MHPAUTOS
  • 31,937 POSTS
Personally i would nor be messing around doing this, you may spend hours trying to get it correct, i would go get the new belt fitted.
Mark (mhpautos)
Jun 11, 2010 at 7:51 PM
