1992 Mazda 323 no spark
1992 MAZDA 323
OZZY2474
Engine Mechanical problem
1992 Mazda 323 4 cyl Front Wheel Drive Manual
I have replaced the distributer, cap, rotor, coil, igniter, condenser, coil wire, main relay, cleaned up the grounds, checked the timing belt and timing, still nothing, what do you think? I'm still getting a "2" code.
Aug 23, 2010 at 3:22 PM
Do you have power going into the coil? Also test the distributor pick-up coil
Aug 23, 2010 at 8:53 PM
GERALD SWARTZ
  • 4 POSTS
hope jumping in on this is ok, I working on the same problem. How do I test power in to coil (have a fluke) and also test the distributor pick-up coil (where is it?)
Sep 9, 2010 at 8:54 AM
