1988 Mazda 323
1988 MAZDA 323
JATMAMBO
Engine Performance problem
1988 Mazda 323 4 cyl Front Wheel Drive Automatic
WHEN TURNING OFF IT IS PRE-IGNIGTING,IS IT IMPORTANT TO HAVE THE TWO VACUCM ADVACE HOSES AROUND THE RIGHT WAY?IF SO WHICH WAY IS THIS?THANK YOU YR ANSWER IS A HUGE HELP!
Apr 27, 2008 at 11:08 PM
WHEN TURNING OFF IT IS PRE-IGNIGTING, what do you mean by this-is it because the engine continues to run when you turn off the key or what?
Apr 28, 2008 at 4:32 AM
JATMAMBO
thank you for yr reply mate...yes that is correct..the motor will not stop intanstly when i turn the key off. it continuies to do about 3-5 revoltions and smells strongly of unburnt gas... maybe the timing to advanced??????
Apr 28, 2008 at 4:50 AM
Okay Mate recheck the ignition timing and also drop your idle speed it might be too high for a base idle.
Apr 28, 2008 at 3:12 PM
JATMAMBO
great!no wonder you are a mechanic because yr answer worked out well problem solved!!!thank you very much for yr time and help big help cheers
Apr 29, 2008 at 3:32 AM
No I'm not a mechanic am I'm just a plain somebody that knows technical stuffs about automotive. Tech. at Large lol.
Apr 29, 2008 at 4:37 AM
