My 2003 Mazda 3 has a continuous flashing air bag light (while I'm driving), what might be causing this problem, how do I fix it?
Dec 30, 2008 at 2:34 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there ,
The SRS has logged a fault with in the operation system, you need to get a scan done to identify which code is set, you will need this code to identify the problem, the SRS will be in-op until the fault is repaired.
