Overheats when idling or low RPMs but does not at high RPMs even if stationary?
2005 NISSAN MAXIMA
171,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
KEDARP
  • 5 POSTS
hi,
I own the vehicle listed above that I was driving from Illinois to California, a2000-milee journey over a 5-day trip.
1,000 miles into the journey, at Rawlins, Wyoming, I smelled a light smell of coolant in the passenger cabin and decided to bypass the heater core with a bypass kit. I did the job myself.
1. After driving for 280 miles from Rawlins to Utah (it was very hot outside), the car suddenly started to overheat when going downhill.
2. I had introduced an air bubble when I bypassed the heater core at Rawlins and had never bled the coolant circuit. In any case, I parked the car for 30 mins when going downhill and it cooled down.
3. Thereafter, after every 15 miles or so, the car overheated regularly, especially at lower rpms.
4. If I raise the rpm of the car (even when stationary) to 5000 rpm, the temperature gauge immediately comes down.
5. I have no coolant leak and the coolant level never changes.
6. The radiator is new'ish and has only 3000 miles on it. The radiator passes a pressure test at 15 & even 20 psi.
7. The engine oil was not milky or frothy. There is no white smoke coming out of the exhaust either.
8. I replaced the thermostat myself 2 days ago, so it has a brand-new thermostat but the overheating problem persists.
9. Both the radiator fans work at both high and low speeds and come on when the engine starts to overheat. The radiator fins are not blocked either.
9. I noticed that the radiator top (inlet) pipe gets very hot when the car is overheating but the bottom (outlet) pipe is stone cold to the touch.
10. I ran the engine for 10 mins at idling with radiator cap removed to eliminate any air pockets.
11. Even when the coolant level is full, I don't see a lot of coolant entering the radiator at lower rpms and it does increase at higher RPMs but I suspect the flow is still quite poor. I have attached a video of the coolant flow (after removing the coolant pipe at top of radiator). The engine was initially at 800 rpm and later at 5000 rpm.
12. I disconnected the heater core inlet hose (tried both inlet and outlet hoses) to see if coolant comes out of the heater core inlet hose with force. But even at 5000 rpm, there is no coolant trying to leave the heater core inlet hose. My car always had a problem getting the inside to heat -- it was *extremely* weak.
Oct 5, 2024 at 10:39 AM
I don't see the video? I have seen the water pump impeller start to go bad/corroded/loose which will cause this kind of problem. The only way to tell for use is it remove it for inspection, here is how. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 5, 2024 at 3:00 PM
KEDARP
  • 5 POSTS
Thanks Ken, let me do what you mention and report back.
Also, in my earlier post, I seem to have missed the video of the coolant flow at idling (800 RPMs) and then at 5,000 RPMs. Let me add it now.
Oct 5, 2024 at 4:48 PM
KEDARP
  • 5 POSTS
Also Ken, in your opinion, is the flow of coolant as in the video typical of a good water pump working at 800 RPMs and 5,000 RPMs?
Oct 5, 2024 at 4:56 PM
Oh yes, it should be flowing much more than that. I would remove the water pump for inspection.
Oct 6, 2024 at 6:31 PM
KEDARP
  • 5 POSTS
Thanks Ken. Appreciate all your help. It was indeed a bad water pump. There was nothing left of the water pump impellers :-)
Oct 8, 2024 at 5:01 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime. Can you please leave us a rating? (copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Thanks in advance!
Oct 9, 2024 at 9:54 AM
KEDARP
  • 5 POSTS
Done. Thanks Ken.
Oct 9, 2024 at 11:52 PM
Thank you :)
Oct 10, 2024 at 11:55 AM
