The master window switch wiring was cut and I got a new switch and I'm trying to figure out which wires go where to rewire this back right.
Jan 26, 2026 at 2:35 PM
CARADIODOC
CERTIFIED EXPERT
Where were they cut, at the switch connector or between the door hinges? if it's between the hinges, do you mean someone actually cut the wires, or they just cracked apart on their own from the flexing?
This is the diagram for the power windows. The second drawing shows the driver's switch terminal layout. Let me know what you need help with.
Jan 26, 2026 at 5:11 PM
CARADIODOC
CERTIFIED EXPERT
Something isn't working with the images. I'll try again later.
Update: Okay, I got the images posted, but I don't know what was causing the trouble. Keep me updated on your progress.
Image (Click to enlarge)
Jan 26, 2026 at 5:24 PM
CARADIODOC
CERTIFIED EXPERT
